It is currently Sun Feb 17, 2019 10:06 am
Post new topic Reply to topic  [ 10 posts ]
 Post subject: Box Error
PostPosted: Fri Mar 06, 2015 3:14 pm
Hi guys,
I have scenario for EMG acquisition and classification that's been working properly for months now. However in the last week or so, OpenVibe keeps reporting next errors:
[ ERROR ] At time 131.000 sec <Box algorithm::(0x000072db, 0x00005828) aka Classifier trainer> stopIndex-trainIndex=1
[ ERROR ] At time 131.000 sec <Box algorithm::(0x000072db, 0x00005828) aka Classifier trainer> Bailing out (from xval)...
[WARNING] Box algorithm <Classifier trainer> has been deactivated because process() function returned error
I haven't changed anything in the programs, and have tried different versions, all with the same error.
Could you be able to help me, please?
 Post subject: Re: Box Error
PostPosted: Mon Mar 09, 2015 1:30 pm
I need some more informations to be able to help you.
Which version of OpenViBE do you use?
What is the k value for the k-fold?
Guillaume
PostPosted: Mon May 04, 2015 4:05 pm
I have the same error when trying to use a classifier trainer.
[ ERROR ] At time 62.844 sec <Box algorithm::(0x00004eb7, 0x00000d37) aka Classifier trainer> stopIndex-trainIndex=1
[ ERROR ] At time 62.844 sec <Box algorithm::(0x00004eb7, 0x00000d37) aka Classifier trainer> Bailing out (from xval)...
I have OpenVibe 1.0.0 and i have other scenarios working perfectly well with classifier trainers. I tried a lot of different k values to try to fix my problem but it didn't work. I use the exact same settings for a classifier trainer in an other scenario (except save path) and i encounter no problem so i really don't get why it doesn't work in that case. I have nearly the same structure as the classification training given as example in the "openvibe\share\openvibe\scenarios" folder so everything looks alright to me.
Any idea what could cause this error ?
I will also try with other stream and stimulations but i don't think it's the origin of the problem.
Thanks for help,
Mathilde
PostPosted: Tue May 05, 2015 12:59 pm
Hi Mathilde,
I will need more informations in order to help you. Can you upload the scenario which give you that error?
Guillaume
PostPosted: Mon May 18, 2015 5:48 pm
Sorry for the late reply... I'm using latest version of openvibe (20/03/15) as I updated the previous one (and have updated all the boxes).
The k-fold value is 7.
Please find attached scenarios that I've been using for the handball demo.
The correct order of application is handball emg acquisition, then classifier trainer and at the end: online.
Thanks a lot :)
Tijana
handball-emg-online.xml [47.85 KiB]
Downloaded 139 times
handball-emg-classifier-trainer.xml [51.68 KiB]
Downloaded 112 times
handball-emg-acquisition.xml [29.98 KiB]
Downloaded 115 times
PostPosted: Thu May 21, 2015 3:29 pm
Could you please put the log you get during execution of the scenario. (Paste them in a file and upload it)
Guillaume
PostPosted: Tue Jun 02, 2015 1:30 pm
Hello Guillaume,
Please find a copy/paste in a .txt file of the errors provided while running the scenarios previously attached.
Please let me know if there's anything else I can provide for you.
Tijana
OpenVibeLog.txt [1.73 KiB]
Downloaded 123 times
PostPosted: Tue Jun 09, 2015 9:33 am
According to the log, the trainer box only received 10 feature vectors. Is that normal?
Guillaume
PostPosted: Tue Jun 09, 2015 12:23 pm
Thanks for the suggestion, now there's no error.
However, when the classification process is done, the third scenario only reacts to one class, not the other one.
For example, if one class is resting and the other EMG, it only recognize resting and not EMG.
What could be the problem?
Tijana
PostPosted: Fri Jun 12, 2015 9:57 am
For me the amount of data is a problem.
Could you try to have more samples of each class?
Guillaume
Users browsing this forum: No registered users and 5 guests
