I am involved in a simple issue: I would like to translate the stimulus output of the Classifier Processor Block in a signal. Any rapid solution to do it? I seemed it simple in theory, but practically I don't know how I could implement it.
Es.:
OVTK_StimulationId_Label_01 >>translate in>> constant signal=1
OVTK_StimulationId_Label_02 >>translate in>> constant signal=2
regards
Roberto
A simple question about stimulus & signals in OpenViBE
Re: A simple question about stimulus & signals in OpenViBE
Hi Roberto,
I'm not sure if it can be easily achieved without doing a new box in C++, or modding an old one. One non-coding alternative you could try is to take the raw output of the classifier (second output) and threshold it with simple DSP box.
Thank you so much for your reply.
Roberto
Roberto
For the community: finally i found a very nice solution. To translate stimulus in signals you can use the Stream Switch box: you have in input your stimulus and whatever signal/streamed matrix, and then you can filter your outputs with DSP (simply transforming outputs in different constants).
Hope this help will be useful
Roberto
Roberto
