OpenViBE::uint64 representation
About the GUI application to design signal processing pipelines
Post Reply
chantrip
Post by chantrip »
Dear Openvibe team
From the code
Code: Select all
uint64 l_ui64CurrentTimeInRepetition=l_ui64CurrentTimeInTrial%(m_ui64RepetitionDuration+m_ui64InterRepetitionDuration);
from file ovpCBoxAlgorithmP300SpellerStimulator.cpp, when I tried to print out the time using cout>>l_ui64CurrentTimeInRepetition, it shows the time in unsigned int 64 bits. Do you know any function that can convert this value into more intuitive sense? i.e. shows in second or milli-second.
Thank you very much
-Jim
lbonnet
Site Admin
Re: OpenViBE::uint64 representation
Post by lbonnet »
Hi Jim,
The time in openvibe is coded on 64 bit unsigned integer, fixed point value (32 bits for the seconds; 32 bits for its divisions).
You can tell the log manager to print these values in seconds using the recently introduced time64 type.
Assuming you are in the box implementation (this is a box):
Code: Select all
this->getLogManager() << LogLevel_Info << "Current time in repetition is : " << time64(ui64CurrentTimeInRepetition) << ".\n";
With the default configuration, you will get the time printed in seconds, with 3 digits after the point (eg. "1.234 sec").
This behaviour is controlled by configuration tokens :
Code: Select all
Kernel_ConsoleLogTimeInSecond = True
Kernel_ConsoleLogTimePrecision = 3
For the messages printed in the console.
Hope this helps.
Laurent-
chantrip
Post by chantrip »
Thank you very much for your answer. That's really helpful :).
-Jim
Post Reply
