Process phase returned bad status??
stefan
Post by stefan »
I’m using some of the available scenarios in openvibe, e.g. the acquisition scenario for the speller with xDawn filter, but I have this error “Acquisition client box has been deactivated because process phase returned bad status”..What does this mean?? I’m using Emotive and it works well, and I’ve used it with openvibe successfully before!!?
Any help, please?
lbonnet
Re: Process phase returned bad status??
Post by lbonnet »
Hi stefan !
This error message usually happens when the acquisition client cannot connect to the acquisition server.
Have you got any more details ? e.g a previous warning message.
If you already managed to get the signal from your emotiv, you shouldn't have any problem with the given scenarios.
You should check the following information:
- the acquisition server is running in background, connected & playing.
- no error message in the acquisition server console
- the acquisition client settings : hostname and port number must match your acquisition server settings (e.g. if the server is running on the same computer as the designer, hostname should be "localhost", port number is specified in both server and client - default value 1024)
- the monitoring scenario works fine (p300-speller-0-signal-monitoring.xml) and displays the signal from your headset
hope this helps a bit
