I downloaded OpenWibe, because i want to use it together with my mindset.
Can please somebody help m? I dont know how to connect OpenVibe and Mindset. How to see EEG from mindset in OpenVibe?
Thank you
Roman, Czech republic
start with NEUROSKY MINDSET
Re: start with NEUROSKY MINDSET
Hi Roman and welcome on board,
I suggest you look at the User documentation section.
The following pages will be interesting :
- Acquire signal with the acquisition server
- Build your first openvibe scenario
And of course, the video tutorial can be very useful for beginners.
I also suggest you try first your Mindset with the demo applications given by Neurosky.
Once you know how to setup everything, the steps are the same with openvibe : connect your headset to a COM port (with low value, see why here) and start the Mindset driver in the Acquisition Server.
Hope this helps !
Hope this helps !
