I am currently encountering an error I don't understand.
It used to work fine a few days ago, and I can't figure out what has changed.
The error is in designer-dynamic.exe on line 2612.
The critical error is GdkPixbuf : gdk_pixbuf_get_pixels : assertion `pixbuf != NULL` failed.
Does anyone have a solution or should I try to uninstall and reinstall ? (I tried to recompile but it didn't work).
Thank you.
Error
First off, I'd suggest lowering the log level to Debug in the configuration manager so we can determine what's going on at the time of the crash.
The configuration file is in /share/openvibe.conf (precompiled version) or openvibe-kernel-omk/trunc/share/openvibe.conf (svn version, must build again for changes to take effect!).
Tokens to edit :
Kernel_MainLogLevel = Debug
Kernel_ConsoleLogLevel = Debug
Kernel_FileLogLevel = Debug
Please post the last lines of the log file dumped in lib/openvibe-designer.log (precompiled version) or /dist/share/openvibe-designer.log
What version are you using and on what machine/OS?
Thanks;
Tokens to edit :
Thanks;
Here are the last lines of the logs
I'm using windows vista SP1
Code: Select all
[ DEBUG ] Searching plugin object descriptor
[ INF ] Initialization took 19321 ms
[ DEBUG ] scenarioDrawingAreaMotionNotifyCB
OK, well it'd be nice to fix the problem though What exactly is the problem when drag and dropping a box?
Alternately, if you recompile in debug mode (see "building the software" forum category) you'll be able to trace the program yourself.
It seems your gtk/gdk installation was altered somehow, if it used to work correctly. Might be a good idea to try reinstalling the software after all! (or at least its dependencies using the dedicated script in /scripts)
Hope that helps...
Hope that helps...
