Hi everyone,
I am having a problem using matlab in openvibe. I followed the steps mentioned in the tutorial but still getting an error.
For example, when trying to implement tutorial 2, this is what I get.
What do you think??
problem when using Matlab with openvibe
- openvibematlab.png (236.27 KiB) Viewed 6387 times
Re: problem when using Matlab with openvibe
Hi Haneen,
May I know what are you actually trying to do?
I am trying to check if matlab is working fine with openvibe on my laptop. I am trying to run "tutorial 2".
http://openvibe.inria.fr/tutorial-using ... atlab+plot
I followed the steps but it seems there is something wrong.
Which version of windows and matlab you have?
I have windows 7 on my 64-bit laptop.
I have MATLAB R2009b , 32 bit.
I switched to a computer that has win32 .. problem solved
Glad that you could solve your problem. As a late reply, the errors shown in the images suggest that matlab wasn't able to find the three .m files in question. Current SVN has a bit more debug output on that.
