Problem With Signal
About the GUI application to design signal processing pipelines
Post Reply
Matress
Problem With Signal
Post by Matress »
Hello.
I hope you can help me.
I hope to do some neurofeedback tomorrow.
I have 4 scenarios set up:
1.Monitoring
2.Acquisition
3.Classifier-Trainer
4.Neurofeedback
But I have a problem. I cannot see the EEG signal. (I have set up the driver for Emotiv. )
I Initially can see the EEG signal in the monitoring scenario but then it disappears!
I am using the Emotiv Headset. I can see the EEG signal using the emotiv testbench.
ANy ideas? How can I check if the driver is working correctly?
I have attached a file showing the stages :
Connecting using driver
Initial EEG Signal
CMD windows
Scenario with module information
Matress
Re: Problem With Signal
Post by Matress »
Hi.
My Temporal filters are as follows:
Butterworth
Band Pass
Filter order: 4
Freq 4hz-20hz
Band Pass Ripple: 0.5db
For Signal Display
Time scale: 10
Display mode: scan
Manual Vertical Scale= true
Vertical scale=20
Does this sound ok?
__________________
When I change the "sample count per sent block" from 32 to 16 I got 2 minutes of EEG Signal displayed. Then it flatlined! Strange.
I have made the simplest scenario with an acquisition client and a signal display.
Sometimes I get strange EEG signal display which looks like barcodes.
jlegeny
Contact:
Post by jlegeny »
Dear Matress,
could you please send me your scenario files as well as a recording of your signal in an attachment? In your first post there is no attached file, maybe you forgot to click on the "add attachment" button after having selected the file (phpbb will indeed not upload the file uless you do so)
For the first tests I would recommend to use automatic vertical scale for the Signal Display box as the values can be extremely small.
Post Reply
