I am controlling a JACO robot arm using EmotivSDK and Openvibe. I ve got few queries.
Right now I am saving the classifier output (which are my control signals) as a *.csv file and calling it in my C# program. I would like to directly send my classifier output in C# program. How do I get/ or construct a dll function for the same? An example, would be very helpful.
Is it possible to add a new box in my binary?? Since I am using 64 bit window, my openvibe is not building from the source files. It is constantly showing the following error (attached).
Help in vrpn analog/button client program in C#
- cmake error.jpg (62.79 KiB) Viewed 3330 times
Re: Help in vrpn analog/button client program in C#
Have you been able to get the correct stimulations as output during your online use? I mean that directing the data to output is not a big task, but to get the actual signal being detected is something more important. have you done that? If yes, then the res is easy, I can help you.
