How can I add the button to the toolbar or open the popup without using the button?
Tanks in advance
Gigi
Here my toolbar
‘window manager’ button missing from the Designer’s toolbar
- toolbar.png (31.14 KiB) Viewed 4245 times
Re: ‘window manager’ button missing from the Designer’s tool
Dear Gigi,
The "window manager" button is not missing in your designer, it is actually here: this is the button with a screwdriver and a wrench crossed displayed on it (the button on the right of the button to close the scenario). If you leave your mouse cursor on this button, it will display "toggles the window manager...". Sorry, this button is indeed not very obvious, but you definitely have it!
Fabien
Fabien
How can I am so blind? Maybe, the icon is a bit misleading.
Thanks a lot.
Gigi
Thanks a lot.
Gigi
Indeed the icon used for this button is probably not very explicit, and often, I also have to hover my mouse over the different buttons to find this window manager button backgigi wrote:How can I am so blind? Maybe, the icon is a bit misleading.
Thanks a lot.
Gigi
