Problem with Scenarios
Cent
Post by Cent »
I have problems when i want to launch a scenario. Only the P300 applicattions run.
When i launch handball scenario (or tie fighter), the only result is that the applicattion crash.
This is the result:
Added resource location 'scene-graz-cross/' of type 'FileSystem' to resource group 'General'
Added resource location 'scene-get-ready-ball/' of type 'FileSystem' to resource group 'General'
Added resource location 'scene-goal/' of type 'FileSystem' to resource group 'General'
Added resource location 'scene-gymnasium/' of type 'FileSystem' to resource group 'General'
Added resource location 'scene-passive-ball/' of type 'FileSystem' to resource group 'General'
Added resource location 'scene-plane/' of type 'FileSystem' to resource group 'General'
Added resource location '../common/scene-plane' of type 'FileSystem' to resource group 'General'
Added resource location '../common/GUI' of type 'FileSystem' to resource group 'General'
Added resource location 'C:\trunk\scripts\..\dependencies\cegui\datafiles\configs' of type 'FileSystem' to resource group 'General'
Added resource location 'C:\trunk\scripts\..\dependencies\cegui\datafiles\fonts' of type 'FileSystem' to resource group 'General'
Added resource location 'C:\trunk\scripts\..\dependencies\cegui\datafiles\imagesets' of type 'FileSystem' to resource group 'General'
Added resource location 'C:\trunk\scripts\..\dependencies\cegui\datafiles\layouts' of type 'FileSystem' to resource group 'General'
Added resource location 'C:\trunk\scripts\..\dependencies\cegui\datafiles\looknfeel' of type 'FileSystem' to resource group 'General'
Added resource location 'C:\trunk\scripts\..\dependencies\cegui\datafiles\lua_scripts' of type 'FileSystem' to resource group 'General'
Added resource location 'C:\trunk\scripts\..\dependencies\cegui\datafiles\schemes' of type 'FileSystem' to resource group 'General'
Added resource location 'C:\trunk\scripts\..\dependencies\cegui\datafiles\xml_schemes' of type 'FileSystem' to resource group 'General'
CPU Identifier & Features
 *   CPU ID: GenuineIntel: Pentium(R) Dual-Core  CPU      E5300  @ 2.60GHz
 *      SSE: yes
 *     SSE2: yes
 *     SSE3: yes
 *      MMX: yes
 *   MMXEXT: yes
 *    3DNOW: no
 * 3DNOWEXT: no
 *     CMOV: yes
 *      TSC: yes
 *      FPU: yes
 *      PRO: yes
 *       HT: no
*** Starting Win32GL Subsystem ***
GLRenderSystem::_createRenderWindow "VR Application - powered by OpenViBE", 1024x768 windowed  miscParams: FSAA=0 FSAAHint= colourDepth=32 displayFrequency=0 gamma=false vsync=false vsyncInterval=1
Created Win32Window 'VR Application - powered by OpenViBE' : 1040x806, 32bpp
GL_VERSION = 1.1.0
GL_VENDOR = Microsoft Corporation
GL_RENDERER = GDI Generic
GL_EXTENSIONS = GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
*** GL Renderer Started ***
Registering ResourceManager for type GpuProgram
GL: Using framebuffer copy for rendering to textures (worst)
GL: Warning: RenderTexture size is restricted to size of framebuffer. If you are on Linux, consider using GLX instead of SDL.
RenderSystem capabilities
RenderSystem Name: OpenGL Rendering Subsystem
GPU Vendor: unknown
Device Name: GDI Generic
Driver Version: 1.1.0.0
 * Fixed function pipeline: yes
 * Hardware generation of mipmaps: no
 * Texture blending: no
 * Anisotropic texture filtering: no
 * Dot product texture operation: no
 * Cube mapping: no
 * Hardware stencil buffer: yes
   - Stencil depth: 8
   - Two sided stencil support: no
   - Wrap stencil values: no
 * Hardware vertex / index buffers: no
 * Vertex programs: no
 * Number of floating-point constants for vertex programs: 15
 * Number of integer constants for vertex programs: 0
 * Number of boolean constants for vertex programs: 0
 * Fragment programs: no
 * Number of floating-point constants for fragment programs: 25924
 * Number of integer constants for fragment programs: 28525
 * Number of boolean constants for fragment programs: 27694
 * Geometry programs: no
 * Number of floating-point constants for geometry programs: 0
 * Number of integer constants for geometry programs: 28416
 * Number of boolean constants for geometry programs: 29806
 * Supported Shader Profiles:
 * Texture Compression: no
 * Scissor Rectangle: yes
 * Hardware Occlusion Query: no
 * User clip planes: yes
 * VET_UBYTE4 vertex element type: yes
 * Infinite far plane projection: yes
 * Hardware render-to-texture: no
 * Floating point textures: no
 * Non-power-of-two textures: no
 * Volume textures: yes
 * Multiple Render Targets: 1
   - With different bit depths: no
 * Point Sprites: no
 * Extended point parameters: no
 * Max Point Size: 10
 * Vertex texture fetch: no
 * Number of world matrices: 0
 * Number of texture units: 1
 * Stencil buffer depth: 8
 * Number of vertex blend matrices: 0
 * Render to Vertex Buffer : no
 * GL 1.5 without VBO workaround: no
 * Frame Buffer objects: no
 * Frame Buffer objects (ARB extension): no
 * Frame Buffer objects (ATI extension): no
 * PBuffer support: no
 * GL 1.5 without HW-occlusion workaround: no
Registering ResourceManager for type Texture
DefaultWorkQueue('Root') initialising on thread 001D2790.
DefaultWorkQueue('Root')::WorkerFunc - thread 001F73F8 starting.
Particle Renderer Type 'billboard' registered
DefaultWorkQueue('Root')::WorkerFunc - thread 001F7428 starting.
SceneManagerFactory for type 'BspSceneManager' registered.
Registering ResourceManager for type BspLevel
SceneManagerFactory for type 'PCZSceneManager' registered.
MovableObjectFactory for type 'PCZLight' registered.
MovableObjectFactory for type 'Portal' registered.
MovableObjectFactory for type 'AntiPortal' registered.
PCZone Factory Type 'ZoneType_Octree' registered
PCZone Factory Type 'ZoneType_Terrain' registered
SceneManagerFactory for type 'OctreeSceneManager' registered.
SceneManagerFactory for type 'TerrainSceneManager' registered.
Parsing scripts for resource group Autodetect
Finished parsing scripts for resource group Autodetect
Parsing scripts for resource group General
Parsing script arrow.material
Parsing script active-ball.material
Parsing script basic-arrow.material
Parsing script cross.material
Parsing script get-ready-ball.material
Parsing script goal.material
Parsing script gymnasium.material
Parsing script passive-ball.material
Parsing script plane-blue.material
Parsing script plane-cyan.material
Parsing script plane-green.material
Parsing script plane-pink.material
Parsing script plane-red.material
Finished parsing scripts for resource group General
Parsing scripts for resource group Internal
Finished parsing scripts for resource group Internal
TerrainSceneManager: Registered a new PageSource for type Heightmap
OIS initialised
Texture: _cegui_ogre_0: Loading 1 faces(PF_A8B8G8R8,256x256x1) with 0 generated
mipmaps from Image. Internal format is PF_A8R8G8B8,256x256x1.
Mesh: Loading gymnasiumNode.mesh.
Texture: gymnasium-briques6.jpg: Loading 1 faces(PF_R8G8B8,512x512x1) with 5 gen
erated mipmaps from Image. Internal format is PF_X8R8G8B8,512x512x1.
Texture: gymnasium-parquet.jpg: Loading 1 faces(PF_R8G8B8,512x512x1) with 5 gene
Texture: gymnasium-plafond.jpg: Loading 1 faces(PF_R8G8B8,128x128x1) with 5 gene
rated mipmaps from Image. Internal format is PF_X8R8G8B8,128x128x1.
Mesh: Loading gymnasium-publicity.mesh.
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Can anyone help me?
Sorry for my english...
Thx :wink:
Edited - please consider formating the message for better clarity, it helps us helping you ! - Yann
jlegeny
Re: Problem with Scenarios
Post by jlegeny »
Hello Cent and welcome to the forums.
Could you please specify the details of your installation ? Which version of OpenViBE and operating system do you use ?
A problem like yours happens usually on virtual machines with Windows guest OS. If you are not using a virtual machine then more details will be necessary to help you with your problem.
One interesting message I noticed while reformating the log is
Jozef, is this supposed to happen ?
Cent
Post by Cent »
I am using windows 7 professional OS (no virtual machine) and the version of OpenViBE is the last version (0.10.1).
I download this version of OpenViBE in the svn.
First run win32_install_dependencies.exe successfully, and after run win32_build.cmd aldo successfully.
Thx for your help.
jlegeny
Post by jlegeny »
What kind of graphics card do you have and do you have your graphics drivers installed ? While looking at your log I noticed that Ogre can not determine your graphics card's vendor and most of the functions are disabled afterwards.
Cent
Post by Cent »
Resolved.
Update the graphic card soft and all run successfully.
Thx :D
