I am currently working with the BCI based on motor imagery and I need to send data (extreamed matrix) obtained from the output of the classifier to an external application. The problem is that the application does not support VRPN protocol and I wonder if it is possible to send data via TCP/IP protocol from Designer, like the "Analog VRPN Server" box or if there's another possibility.
Thanks in advance,
Jose
Sending data from Openvibe to an external app via TCP/IP
Re: Sending data from Openvibe to an external app via TCP/IP
Did you get the solution? May be I can help you. What I get from your post is that Analog AnVRPN won`t work you, rite?
Did you do it?? I need to send information via socket to, but i dont know how.(I can´t use desinger.sh )
