--no-gui --play versus --play
ddvlamin
Post by ddvlamin »
I encountered a weird problem that is hard to reproduce. When I play a certain scenario (to train for example the classifier for the P300) with the --play option at the command-line then everything works fine all the time. However, when I want to run it with --no-gui --play, then sometimes the classifier does not start its training. If I run it again with the --no-gui option removed everything works fine again. Someone encountered this problem and knows how to deal with it?
Dieter
