hi,
I am a beginner to this software.Yesterday I found that if I add a temporal filter to the matlab scipts in tuto3_sinus_generater.xml .All the outputs of filter were zeros!
I want to know what's wrong with this script.
Shelldream
About the matlab scripts
Re: About the matlab scripts
I don't know this script but given its name I guess it generates a perfect sinus signal at a given frequency, so if you filter it in another frequency (using the temporal filter), well, the output should actually be 0... Is that what you do?
Hi,fabien.lotte
Thank you for your help. But I checked my filter ,it was all right.Here I attach my scenarios and the matlab files. I think the problems result from the format of the matlab script output whic is different from the dafault format of data in this softwar.
I tried to attach the matlab files ,but failed.You can still find these matlab files in the ……\share\openvibe-scenarios\box-tutorials\matlab,because my scenarios call the same matlab functions as the tutorials.
Could you help me to find the problems?
shelldream
shelldream
- foram_matlab.xml
- (16.54 KiB) Downloaded 243 times
- foram_matlab1.xml
- (23.74 KiB) Downloaded 248 times
Dear Shelldream,
I've tried your scenario (actually it was the first time for me using the Matlab scripting box), and I observed the same problem. And indeed your temporal filter looks correct. I actually tried different cutoff frequency but whatever the frequencies I used the output was zero. So you are right there is probably a problem with the matlab scripting box (or maybe with the temporal filter one?). When using simpleDSP on the data produced by the matlab scripting box, everything went well, but when using the temporal filter, then problems arised. So I guess it is probably due to a timing issue or a problem with the sampling frequency. However I checked the matlab files and the sampling frequency seemed correct so I don't know what could be the problem. Maybe Laurent would have a clue since he programmed the matlab scripting box: Laurent, any idea?
best,
Fabien
best,
Fabien
Dear OpenVibe community :
I think that I have a similar problem with the Matlab toolbox. I've designed a Matlab script for artifact cancellation using a reference electrode (adaptive LMS).
It seems that the output of the box has a timing issue that makes crash many boxes. However the output can be visualized and exported in .ov or .csv file but the same problem occurs when I use this exported .ov file.
Example of error message on a CSP scenario using the adaptive filter:
Here is a EEG recordings (14 channels) :
https://docs.google.com/file/d/0ByqLgre ... sp=sharing
Do you have a idea how can I handle this ?
Thank you in advance
Korczowski L.
Engineer Student
INRIA-LORIA Nancy
I made a simple scenario in which OpenVibe crash (LMS_crash.zip).[ ERROR ] At time 0.250 sec, plugin code caused a crash 1 time(s)
[ ERROR ] [name:Left Stimulation epoching]
[ ERROR ] [identifier:(0x00007f0e, 0x000065cd)]
[ ERROR ] [algorithm class identifier:(0x426163d1, 0x324237b0)]
[ ERROR ] [location:processing callback]
[ ERROR ] At time 0.250 sec, plugin code caused a crash 2 time(s)
[ ERROR ] At time 0.250 sec, plugin code caused a crash 3 time(s)
[ ERROR ] At time 0.250 sec, plugin code caused a crash 4 time(s)
[ ERROR ] At time 0.250 sec, plugin code caused a crash 5 time(s)
[ FATAL ] This plugin has been disabled !
[WARNING] <Player::can not reach realtime> 2 second(s) late...
[WARNING] <Player::can not reach realtime> 1 second(s) late...
[ INF ] <Player::can not reach realtime> 0 second(s) late...
Korczowski L.
Engineer Student
INRIA-LORIA Nancy
- LMS_crash.zip
- (5.44 KiB) Downloaded 237 times
I updated my LMS filter scenario and the matlab files to correct some stuff. (LMS_filter_v2.zip)
I still have the same issue. As one can see, even if I set the sample rate of my outputs in the matlab scripting box, the sample rate is set to zero in the exported data. (problem_OV_matlab_small.JPG)
Louis
Louis
- Sample Rate issue example in matlab scripting box
- problem_OV_matlab_small.JPG (194.58 KiB) Viewed 7351 times
- LMS_filter_v2.zip
- (9.65 KiB) Downloaded 219 times
Hello all,
there's definitely something fishy in all this. We're looking into it.
It seems that the sampling rate was not parsed properly if it was set inside Matlab. This has been fixed in r3522.
