I tried to apply the coordianate I extrapolate from a file I had of a 10-5 system but I had an error:
[ ERROR ] At time 167772160 (0xa000000)<Box algorithm::2D topographic map> Coord
inates of electrode #0 (0x0)(AF3), are not normalized, aborting model frame elec
trode coordinates computation
[WARNING] Box algorithm <2D topographic map> has been deactivated because proces
s phase returned bad status
and the same for 3D topographic...
What does it means: "are not normalized"?
I've attached the file.
Coordinates for channel localisation
- electrode_set_emotiv_cartesian.txt
- (660 Bytes) Downloaded 277 times
Re: Coordinates for channel localisation
Dear MarcoRotonda,
normalized means that the length of the actual position vector should be 1. The electrode localization are projected on the scalp from a unit sphere.
Tell me if it helps.
