Dear OpenViBE developers,
I'm sorry if this is a stupid question, is it possible to display epoched signal? If its possible, where exactly I can tap input for Signal Display Box?
I'm learning how randomly-looked EEG signal transforms step by step until it can be recognised (feature extracted), from the motor-imagery sample scenario. But I'm stuck after the signal exits from epoching box.
And also, what does log(1+x) do after signal's power calculated? I've managed to get this screenshot after bypassing continuous signal to the DSP box:
I must confess I'm not really good with mathematics of signal processing, but from the screenshot I don't understand what is the purpose of the logarithm. Visually, signal power is more recognizable than logarithm one.
Please pardon my stupidness.
Thank you
Displaying epoched signal
- signal-flow.jpg (116.69 KiB) Viewed 2602 times
Re: Displaying epoched signal
Hi ariandy !
In fact, we don't want to detect the signal peaks, but power peaks on a given frequency band - not visible on the signal display.
The log(1+x) gives a logarithmic distribution of the power, to get close to a normal distribution.
I hope this helps, but if an openviber with better knowledge of signal processing theory can precise it, (s)he's welcomed
Yes it is. Link a Signal Display after the Time Based Epoching, play the scenario and change the configuration of the signal display panel. If you want to see every epoch, use a time scale equals to the epoch duration (1 sec in this scenario). Please change this time scale after playing the scenario (there is a bug we need to fix when the time-scale has been previously set). You will see Every epoch computed (i.e. every intervals).is it possible to display epoched signal?
I am not a specialist of signal processing and mathematical operations, but I can try to explain what I knowAnd also, what does log(1+x) do after signal's power calculated? [...] Visually, signal power is more recognizable than logarithm one.
