I am beginner in openvibe and I am trying to develop a p-300 speller using emotiv as signal acquisition device.
I have built 4 scenarios (acquisition, trainning, classification and online-implementation), however the results obtained during
the last stage did not show any match between the target and the result.
The largest acquistion was made with 20 trials (10 repetions each). Although the trainning stage shown 76% of accuracy, during the online implementation the best obtained result was three matches of row/column.
Here are the scenarios I have been applying.
Does anyone know what might be wrong with this?
Thanks!
Gil Braz
P-300 Speller: bad results
- FORUM.rar
- (21.69 KiB) Downloaded 243 times
Re: P-300 Speller: bad results
I haven't taken a look at your scenarios, but I assume you started from the ones that came with openvibe.
Given that you use the Emotiv set, which generally has lower SNR, I would go for at least 20 repetitions, where you might want to use averaging instead of single trial analysis and voting. If you average all 20 repetitions then you might want to record more than 30 trials.
