libopenvibe-plugins-contrib-signal-processing.so: undefined symbol: _ZN4itpp3MatIdE8set_sizeEiib
Posted: Sat Dec 26, 2020 1:21 am
I builded Openvibe 3.0.0 in Linux mint 19 Tara and fail in motor-imagery-CSP/mi-csp-2-train-CSP.xml
The execute crashed after 7 minutes:
[WARNING] Box Graz visualization [(0x00dd290d, 0x5f142820)] should be updated
[WARNING] Scenario requires 'update' of some box(es). You need to replace these boxes or the scenario may not work correctly.
[ INF ] Initialization took 1564 ms
[ INF ] At time 431.234 sec <Box algorithm::(0x00004125, 0x0000536f) aka CSP Spatial Filter Trainer> Received train stimulation - be patient
/home/nahuel/Downloads/Openvibe/openvibe-3.0.0-src/dist/extras-Release/bin/openvibe-designer: symbol lookup error: /home/nahuel/Downloads/Openvibe/openvibe-3.0.0-src/dist/extras-Release/lib/libopenvibe-plugins-contrib-signal-processing.so: undefined symbol: _ZN4itpp3MatIdE8set_sizeEiib
Can you help me?
Thanks!
Can you help me?
Thanks!
