Event Id, Time duration
ra75763
Post by ra75763 »
This is my recorded signal in csv. How can I increase the Time interval 0.004 sec in openvibe designer ? i.e. How can I change 250 Hz. I am getting around 7000 events for 70 sec recording.
I am using OpenBCI to generate eeg. then Openvibe aq. server and designer for recording.
Also I am not clear about the data explanation. I mean to say Event Id with Fp1 .
I will be grateful if any one help me by explaining.
Time:250Hz Epoch FP1 Event Id Event Date Event Duration
0 0 42687.49219 33552:33553
0.004 0 42687.49219
0.008 0 42687.49219
0.012 0 42687.49219
0.016 0 42687.49219
0.02 0 42687.49219 33554
0.088 0 42698.33594
0.092 0 42702.51563
0.096 0 42691.78516
0.1 0 42687.49219 33552:33553
Re: Event Id, Time duration
A question Off topic you use the box csv writer deprecated? because there is no ',' between your values it's weird. ^^
For your recording you want to go from 250Hz to 100Hz is that? You're an old box downsampling that could help you.
Regarding your last sentence I did not understand at all "I mean to say Event Id with Fp1."
ra75763
Post by ra75763 »
How can I save the events ? To plot p300
WWWWWH : Who, What, Where, When, Why, How....
Can you be clearer your sentence can have many answers.
PS : I'm not a bot, Hi and other usual things are not useless
