Hello!
I'm new to this forum and EEG. I downloaded openvibe-1.3.0-setup.exe. v1.3.0 and installed. I run openvibe-designer.cmd it will stop working. OS is windows7. Please help me
First, make sure you are using the latest official version of OpenViBE, and not either an old version or a third party version.
A good place to start learning about the platform is to read the existing documentation. Several documents and tutorials are dedicated to explaining the use of the platform and its associated tools.
HI,
I can add : If you haven't this option. It's maybe because you have install python with anaconda or other all in one software, you must add to path python manually.
Thibaut
