g.tec USBamp in Linux
kotaniBCI
Post by kotaniBCI »
As a topic, my purpose is to use g.USBamp from openvibe 2.1 in Linux(Ubuntu 16.04 LTS).
I’ve installed the driver of gUSBamp and connected g.USBamp to PC. Probably, I succeed to install the driver, cos attached demo program worked correctly.
Then I opened Acquisition Server but, there was no gUSB.amp in the driver list.
Firstly, I’ve installed the driver of gUSB.amp ver 1.16.00. However, it didn’t work correctly. Secondly, I’ve installed 1.14.02, cos I heard that driver of openvibe was made for gUSB.amp ver 1.14.02. However, it also didn’t work.
I want to add gUSB.amp in the list of the Acquisition Server. Does anybody know why this happens? Any advice is welcome. I will appreciate your support.
Re: g.tec USBamp in Linux
Hi, you need the gUSBAmp C API from gtec to compile OV yourself with the usbamp support. Please look at the file
extras/cmake-modules/FindThirdPartyGUSBampCAPI.cmake
to see what the compilation is exactly looking for and from where.
