When I use Windows, I can see several COM ports listed in the acquisition server's 'Device' input (under 'Driver Properties'), but on Ubuntu, I see only 'Automatic'. And if I try to proceed with 'Automatic' (using the OpenBCI driver), I get the following output:
[ INF ] Connecting to device [OpenBCI]...
[ INF ] OpenBCI: Configured 'missing sample delay before reset' to 1000 ; this can be changed in the openvibe configuration file setting the AcquisitionDriver_OpenBCI_MissingSampleDelayBeforeReset token
[ INF ] OpenBCI: Configured 'dropped sample count before reset' to 5 ; this can be changed in the openvibe configuration file setting the AcquisitionDriver_OpenBCI_DroppedSampleSafetyDelayBeforeReset token
[ INF ] OpenBCI: Configured 'dropped sample safety delay before reset' to 1000 ; this can be changed in the openvibe configuration file setting the AcquisitionDriver_OpenBCI_DroppedSampleSafetyDelayBeforeReset token
[ INF ] OpenBCI: Status - ** NO ** Daisy module option enabled, 11 channels -- 8 EEG and 3 accelerometer -- at 250Hz.
[ ERROR ] OpenBCI: Port has not been configure and driver could not open any port
[ INF ] Disconnecting.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 003: ID 138a:0017 Validity Sensors, Inc.
Bus 001 Device 002: ID 80ee:0021 VirtualBox USB Tablet
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub[/code
My Ubuntu environment is running in VirtualBox (within another Ubuntu environment, but the host environment is not the right version of Ubuntu).
