Connection failure using Generic Raw Telnet Reader driver
Posted: Sat Aug 19, 2017 2:45 pm
I'm attempting to connect the Acquisition Server to an OpenBCI UltraCortex w/Cyton board and believe I have the Generic Raw Telnet Reader driver configured properly; however, I see the following error on the console and in the log and am uncertain what step to take to troubleshoot this.
Log Result:
[ INF ] Adding plugins from [C:/Program Files (x86)/openvibe//bin/openvibe-plugins-stream-codecs*.dll]
[ INF ] Added 21 (21) plugin object descriptor(s) from [C:/Program Files (x86)/openvibe//bin/openvibe-plugins-stream-codecs.dll]
[WARNING] Registery key Software\VB and VBA Program Settings\Brain Quick - System 98\EEG_Settings is not initialized
[ INF ] Loading plugin: ExternalStimulations (deprecated)
[ INF ] Loading plugin: TCP Tagging
[ INF ] Loading plugin: LSL Output
[ INF ] Connecting to device [Generic Raw Telnet Reader]...
[ ERROR ] Could not connect to server [localhost:12345 (12345)]
[ ERROR ] Connection failed...
[ INF ] Disconnecting.
I have confirmed that the OpenBCI Gui application and the Cyton/dongle are all communicating properly (I am observing brain wave activity). Also I originally used the default Generic Oscillator driver to test things after installing the P300 Speller software and it appeared successful.
[ INF ] Connecting to device [Generic Oscillator]...
[ INF ] Connection succeeded !
[ INF ] Starting the acquisition...
[ INF ] External stimulations (deprecated) activated...
[ INF ] Now acquiring...
[ INF ] Stopping the acquisition.
Does anyone have any experience (or suggestions) in properly establishing a connection with OpenBCI equipment or could provide any insight into troubleshooting the Raw Telnet Reader driver?
Being new to this software- I am hopeful I have just missed something simple, please let me know if I can provide any other detail.
Other Specifics:
OS: Windows 7, 64 bit
Install: openvibe-1.3.0-setup file downloaded from the http://openvibe.inria.fr/ website
Log Result:
Other Specifics:
