Acquisition server - change electrode name to default
alter
Post by alter »
Hi All,
Any of you encountered the issue above?
I change the name of sensors, electrodes, apply and connect- play aq server.
In designer I got the same old values oscillator 1,2,..
Any idea why this happened?
Many thanks.
System & App
openvibe 1.2.1
windows 7u / 64bit / 4GBRAM/ etc.
Re: Acquisition server - change electrode name to default
Hi, this is because there's a bug in the generic oscillator driver that it overwrites the user-specified channel names.
If you really detest the default names, you can use channel rename box in designer to change them. :) We'll fix the bug for the next release, thanks for the report.
alter
Post by alter »
jtlindgren wrote:Hi, this is because there's a bug in the generic oscillator driver that it overwrites the user-specified channel names.
Thank Jussi,
Good to know!
Please be so kind and help me on this one.
I set the designer to save data using the generic stream writer.
How can I pipe saved data to the acquisition server ? Or should I pass the AS?
Many thanks.
Alter
alter
Post by alter »
gdf is the answer.
