openvibe + emotiv eeg raw
alter
Post by alter »
Dear All,
I decided to use in my research the emotiv device. Some say good things about the emotiv same bad things. The fact is that I have the Emotiv Raw EEG and it should work with Openvibe.
Installing the openvibe was piece of cake, configuring to work with Emotiv is different story.
The Emotiv did not provide me the SDK premium and told me that they are make it free on github.
OK, I said, go to github download sdk, set the location of edk.dll make everything acceding with indications.
The think is that once I click in open vibe acquisition-server (where driver is emotiv EPOC) I got the error from the (I assume SDK) "can't connect to EmoEngine. EDK Error Code 1282.Conenction failed...Disconnecting.
I'm running a medical research, after I spend 2 hours with them on the chat, nothing was happened.
I would like to ask you for your help, and for this I thank you in advance.
Many thanks,
Alter
alter
Re: openvibe + emotiv eeg raw
Post by alter »
Well, I see that no one is answer...
