It is currently Wed Jan 29, 2020 5:58 am
PostPosted: Fri Dec 11, 2015 7:50 pm
I am trying to use OpenViBE to read and analyze data in real time from a Biosemi Active Two Mark II. The Acquisition server (V1.1.0) recognizes my peripheral and indicates that the connection status is fine. However, when I try to connect to the Active Two so I can begin to send data to the Designer I get the following error. "An error occurred while dropping unused samples at initialization time." which causes the connection to fail.
The acquisition aborts without the Device information window popping up. I have verified that the CMS and DRL are in range. Biosemi's Actiview software also reads from the hardware on the same machine. I have tried the same procedure on a 32 and 64 bit windows 7 platform with the same results.
Has anyone had a similar problem or have advice on getting open vibe to work with Biosemi hardware?
Thanks in advance.
KJ
