[Solved] Acquisition server with Emotiv headset on Linux
DarkPatate
Post by DarkPatate »
I want use the Openvibe software with my Emotiv headset, my university bought the Research SDK only for Linux. Unfortunately, and contrary to Windows, the Emotiv headset doesn't appear in the Acquisition server list.
To install OpenVibe I followed this instructions :
|Building.on.Linux|
1. Short story
# cd scripts
# ./linux-install_dependencies
# ./linux-build
Before doing the last command, I change the cmake-module, but I'm not sure I did the correct operation, specially for the the paths. Indeed, all informations I found show Windows Path.
See the beginning of my FindThirdPartyEmotivAPI.cmake :
# edkErrorCode.h EmoStateDLL.h
	#FIND_PATH(PATH_EmotivAPI edk.h  PATHS "/home/simeon/EmotivResearch_2.0.0.20"  "/home/simeon/EmotivResearch_2.0.0.20/doc/examples_Qt/example5" ${OV_CUSTOM_DEPENDENCIES_PATH})
	FILE(GLOB PATH_Candidates
		"C:/Program Files/Emotiv Development Kit*"
		"/home/simeon/EmotivResearch_2.0.0.20*"
For information, my OpenVibe version is 1.0.0, my Emotiv SDK version is 2.0.0.20 and my Ubuntu version is 14.04 LTS.
I hope you can help me!
Siméon.
gserrier
Re: Acquisition server with Emotiv headset on Linux
Post by gserrier »
The edition you made looks fine.
You should also:
- remove the win32 guard at the beginning of the file
- remove following lines
TARGET_LINK_LIBRARIES(${PROJECT_NAME} Delayimp.lib )
SET_TARGET_PROPERTIES(${PROJECT_NAME} PROPERTIES LINK_FLAGS "/DELAYLOAD:edk.dll")
If it doesn't work, tell me.
Guillaume
DarkPatate
thanks for your help.
I did the modifications but it doesn't seem to work (the rebuilt had not generate any errors). See after my entire FindThirdPartyEmotivAPI.cmake.
The Emotiv headset doesn't appear in the Acquisition Server list, maybe another configuration is needed?
Moreover all the dynamic library files are .so and not .dll, it's maybe an explication?
If you want more details, tell me!
Thanks in advance!
Siméon.
The file:
# Finds Emotiv SDK
# Adds library to target
# Adds include path
	FOREACH(Candidate_folder ${PATH_Candidates})
		# MESSAGE(STATUS "Found path ${PATH_Candidate}")
		LIST(APPEND PATH_Candidates ${Candidate_folder}/doc/examples/include)
	ENDFOREACH(Candidate_folder ${PATH_Candidates})
	# MESSAGE(STATUS "Emotiv paths found ${PATH_Candidates}")
	FIND_PATH(PATH_EmotivAPI edk.h  PATHS ${PATH_Candidates} ${OV_CUSTOM_DEPENDENCIES_PATH})
	IF(PATH_EmotivAPI)
		MESSAGE(STATUS "  Found Emotiv API...")
		INCLUDE_DIRECTORIES(${PATH_EmotivAPI})
		FIND_LIBRARY(LIB_EmotivAPI edk PATHS "${PATH_EmotivAPI}/../lib")
		IF(LIB_EmotivAPI)
			MESSAGE(STATUS "    [  OK  ] lib ${LIB_EmotivAPI}")
			TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${LIB_EmotivAPI} )
			# To delay load EDK.dll and redistribute binary
			#TARGET_LINK_LIBRARIES(${PROJECT_NAME} Delayimp.lib )
			#SET_TARGET_PROPERTIES(${PROJECT_NAME} PROPERTIES LINK_FLAGS "/DELAYLOAD:edk.dll")
		ELSE(LIB_EmotivAPI)
			MESSAGE(STATUS "    [FAILED] lib Emotiv edk.lib")
		ENDIF(LIB_EmotivAPI)
		# Copying of DLL files is not needed anymore because of delay load library
		ADD_DEFINITIONS(-DTARGET_HAS_ThirdPartyEmotivAPI)
	ELSE(PATH_EmotivAPI)
		MESSAGE(STATUS "  FAILED to find Emotiv API")
	ENDIF(PATH_EmotivAPI)
DarkPatate
Will there a log file I can give you?
gserrier
Post by gserrier »
Well the build log should be a good thing.
DarkPatate
I didn't find the build log file, where is it ?
I found several CMake logs, but I'm not sure if it's that.
Thanks a lot ! :-)
CMakeError.log
Find in /dependencies/tmp/glfw-3.0.4/CmakeFiles
(5.04 KiB) Downloaded 321 times
CMakeOutput2.log
Find in /local-tmp/linux-Release/CMakeFiles
(28.14 KiB) Downloaded 320 times
CMakeOutput.log
(25.95 KiB) Downloaded 296 times
gserrier
Post by gserrier »
I need the log that are generated during the execution of the ./linux-build
Run the command
./linux-build &> build_log.txt
and then join the build_log.txt file.
DarkPatate
Here is the log file :-)
build_log.txt
Build log file
(167.96 KiB) Downloaded 316 times
gserrier
Post by gserrier »
Could you try to locate the file edk.h in your computer?
DarkPatate
I have several edk.h file, each example folder have its own file : /home/simeon/EmotivResearch_2.0.0.20/doc/examples_Qt/examplex with x a number between 1 and 5. In the CMake file, I chose arbitrary the 5th folder.
gserrier
Post by gserrier »
Ok, could you run the command
tree > emotiv_tree.txt
in the folder "/home/simeon/EmotivResearch_2.0.0.20" and put it in the forum?
PS: if the command do not exist, install the package tree.
DarkPatate
Here is the tree file.
emotiv_tree.txt
Tree file
(16.99 KiB) Downloaded 329 times
gserrier
Post by gserrier »
Ok, try to replace your FindThirdPartyEmotivAPI.cmake by this
# Finds Emotiv SDK
# Adds include path
      LIST(APPEND PATH_Candidates ${Candidate_folder}/doc/examples_Qt/example5/include)
   IF(PATH_EmotivAPI)
      FIND_LIBRARY(LIB_EmotivAPI edk PATHS "${PATH_EmotivAPI}/../../lib")
      IF(LIB_EmotivAPI)
      ELSE(LIB_EmotivAPI)
If it doesn't work please report the build log.
Guillaume
DarkPatate
It doesn't work, Emotiv doesn't appear in the Server Acquisition list.
Here is the file:
build_log2.txt
(167.96 KiB) Downloaded 312 times
gserrier
Post by gserrier »
Arf, alright uncomment the line
and give me the build log.
