[Solved] Acquisition server with Emotiv headset on Linux
DarkPatate
Re: Acquisition server with Emotiv headset on Linux
Post by DarkPatate »
Here is the file :p
build_log3.txt
(168.09 KiB) Downloaded 272 times
gserrier
Post by gserrier »
Ok try this
# Finds Emotiv SDK
# Adds library to target
# Adds include path
# edkErrorCode.h EmoStateDLL.h
   #FIND_PATH(PATH_EmotivAPI edk.h  PATHS "/home/simeon/EmotivResearch_2.0.0.20"  "/home/simeon/EmotivResearch_2.0.0.20/doc/examples_Qt/example5" ${OV_CUSTOM_DEPENDENCIES_PATH})
   FILE(GLOB PATH_Candidates
      "C:/Program Files/Emotiv Development Kit*"
      "/home/simeon/EmotivResearch_2.0.0.20*"
   FOREACH(Candidate_folder ${PATH_Candidates})
      # MESSAGE(STATUS "Found path ${PATH_Candidate}")
      LIST(APPEND PATH_Candidates ${Candidate_folder}/doc/examples_Qt/example5)
   ENDFOREACH(Candidate_folder ${PATH_Candidates})
   MESSAGE(STATUS "Emotiv paths found ${PATH_Candidates}")
   FIND_PATH(PATH_EmotivAPI edk.h  PATHS ${PATH_Candidates} ${OV_CUSTOM_DEPENDENCIES_PATH})
   IF(PATH_EmotivAPI)
      MESSAGE(STATUS "  Found Emotiv API...")
      INCLUDE_DIRECTORIES(${PATH_EmotivAPI})
      FIND_LIBRARY(LIB_EmotivAPI edk PATHS "${PATH_EmotivAPI}/../../lib")
      IF(LIB_EmotivAPI)
         MESSAGE(STATUS "    [  OK  ] lib ${LIB_EmotivAPI}")
         TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${LIB_EmotivAPI} )
         # To delay load EDK.dll and redistribute binary
         #TARGET_LINK_LIBRARIES(${PROJECT_NAME} Delayimp.lib )
         #SET_TARGET_PROPERTIES(${PROJECT_NAME} PROPERTIES LINK_FLAGS "/DELAYLOAD:edk.dll")
      ELSE(LIB_EmotivAPI)
         MESSAGE(STATUS "    [FAILED] lib Emotiv edk.lib")
      ENDIF(LIB_EmotivAPI)
      # Copying of DLL files is not needed anymore because of delay load library
      ADD_DEFINITIONS(-DTARGET_HAS_ThirdPartyEmotivAPI)
   ELSE(PATH_EmotivAPI)
      MESSAGE(STATUS "  FAILED to find Emotiv API")
   ENDIF(PATH_EmotivAPI)
DarkPatate
This time the compilation aborted.
build_log4.txt
(36.94 KiB) Downloaded 261 times
gserrier
Post by gserrier »
That's a progression :)
Try remove
#include <windows>
from files
/home/simeon/Logiciels/openvibe-1.0.0/applications/platform/acquisition-server/src/drivers/emotiv-epoc/ovasCDriverEmotivEPOC.h
/home/simeon/Logiciels/openvibe-1.0.0/applications/platform/acquisition-server/src/drivers/emotiv-epoc/ovasCConfigurationEmotivEPOC.h
DarkPatate
Arf, another abort ! We will get there :p
build_log5.txt
(37.2 KiB) Downloaded 271 times
gserrier
Post by gserrier »
All compilation error are related to error handling.
We can try to remove them to see. It's not clean but if it's work, should be enough for now :)
in file /home/simeon/Logiciels/openvibe-1.0.0/applications/platform/acquisition-server/src/drivers/emotiv-epoc/ovasCDriverEmotivEPOC.cpp
Remove the block
	if(_putenv_s("PATH",m_sCommandForPathModification) != 0)
		m_rDriverContext.getLogManager() << LogLevel_Error << "[INIT] Emotiv Driver: Failed to modify the environment PATH with the Emotiv SDK path.\n";
		return false;
and replace the block
	__try
		m_tEEEventHandle = EE_EmoEngineEventCreate();
		m_ui32EDK_LastErrorCode = EE_EngineConnect();
	__except(EXCEPTION_EXECUTE_HANDLER)
		m_rDriverContext.getLogManager() << LogLevel_Error << "[INIT] Emotiv Driver: First call to 'edk.dll' failed.\n"
			<< "\tTo use this driver you must have the Emotiv SDK Research Edition (or above) installed on your computer.\n"
			<< "\tAt first use please provide in the driver properties the path to your Emotiv SDK (root directory)\n"
			<< "\te.g. \"C:\\Program Files (x86)\\Emotiv Research Edition SDK_v1.0.0.4-PREMIUM\"\n"
			<< "\tThis path will be saved for further use automatically.\n";
		return false;
by
DarkPatate
Another error :p It stops at 98%, almost !
build_log6.txt
(47.25 KiB) Downloaded 268 times
just to chime in: Emotiv Epoc on Linux is not 'officially' supported by OpenViBE (no Linux icon in the Emotiv entry of 'supported hardware' web page).
Getting it to work may require some effort, but it can be feasible. Maybe you are already close! Afaik the core dev team
does not have access to the Emotiv Linux SDK, making it difficult from our side to support Epoc on Linux.
This old post may also be of interest,
viewtopic.php?f=5&t=4277
Btw, I made a personal log entry a few years back that the required mods look relatively simple, but I didn't attempt actual integration for example because we cannot test it without the SDK.
DarkPatate
Ok, I hope we'll be able to success!
Unfortunately, the github link in your cited post is broken :/
Google finds the following,
https://github.com/tbronchain/openemo
DarkPatate
Oh sorry, shame on me! However Google is my friend :p
I will try a second installation, in parallel of the first. To continue that of Guillaume after.
Thanks!
DarkPatate
I have an error when I want to build the dependencies with the patch
Setting target folder to [/home/simeon/openvibe/scripts/software]...
Setting environment configuration script to [/home/simeon/openvibe/scripts/software/environment-configuration-script]...
Creating target tree structure...
Checking native dependencies...
  You are currently running Ubuntu
  It is possible to install native packages in order to avoid some potential
  errors / save time. Such installation requires root access. If you want
  to continue with native packages, answer 'yes' (recommanded)
  Do you want to install native packages (y) ? automatically selected yes
  Installing native packages on background...
error: error in native package installation
Lecture des listes de paquets…
Construction de l'arbre des dépendances…
Lecture des informations d'état…
Aucune version du paquet libogre-dev n'est disponible, mais il existe dans la base
de données. Cela signifie en général que le paquet est manquant, qu'il est devenu obsolète
ou qu'il n'est disponible que sur une autre source
E: Le paquet « libogre-dev » n'a pas de version susceptible d'être installée
Do you know what can I do?
gserrier
Post by gserrier »
This is a known issue. Debian made some changes in package name and that leads to that kind of error.
But it has been fix in version 1.0.
Which version are you trying to use?
PS: basically this patch are what we were trying to do.
DarkPatate
I followed the Github (and Readme file) instructions in using the command:
4- Checkout openvibe sources (let's assumer that you are downloading them in your home folder)
	-> cd && svn checkout svn://scm.gforge.inria.fr/svn/openvibe/trunk openvibe
gserrier
Post by gserrier »
Okay,
Definitely not the right version :).
Use that command to checkout openvibe.
git clone https://gforge.inria.fr/git/openvibe/openvibe.git
in your home directory
Guillaume
