[Solved] Acquisition server with Emotiv headset on Linux
Re: Acquisition server with Emotiv headset on Linux
Ok, I downloaded the right version.
Now, the patch seems to not work, see the attached log file.
- patch-log.txt
- (1.94 KiB) Downloaded 293 times
In patchEmotiv.sh
Replace
By
Guillaume
Replace
OPENVIBE_EMOTIV_PATH="${OPENVIBE_LOCATION}/${OPENVIBE_DIR}/openvibe-applications/acquisition-server/trunc/src/emotiv-epoc"
OPENVIBE_EMOTIV_PATH="${OPENVIBE_LOCATION}/${OPENVIBE_DIR}/applications/platform/acquisition-server/src/drivers/emotiv-epoc"
So, I passed all the steps before the compilation. But the build aborted, see the log file.
- build_log.txt
- (17.72 KiB) Downloaded 289 times
In file FindThirdPartyEmotivAPI.cmake
replace
by
replace
TARGET_LINK_LIBRARIES(${PROJECT_NAME}-dynamic ${LIB_EmotivAPI} )
TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${LIB_EmotivAPI} )
An other error, see the log file :p
- build_log2.txt
- (39.91 KiB) Downloaded 278 times
Looks like we just fall back to error we've got friday. With all windows related issues.
I took a second look to the first solution (the one from friday) we were try to set up. I think the problem comes from a mistake I made in the cmake file. So lets try with this solution and set it up to the end, and later I will insert all modifications in the openvibe repo to have it work properly. Sorry to use you as a tester
Replace the content of FindThirdPartyEmotivApi.cmake by
Guillaume
# Finds Emotiv SDK
# Adds library to target
# Adds include path
# edkErrorCode.h EmoStateDLL.h
#FIND_PATH(PATH_EmotivAPI edk.h PATHS "/home/simeon/EmotivResearch_2.0.0.20" "/home/simeon/EmotivResearch_2.0.0.20/doc/examples_Qt/example5" ${OV_CUSTOM_DEPENDENCIES_PATH})
FILE(GLOB PATH_Candidates
"C:/Program Files/Emotiv Development Kit*"
"/home/simeon/EmotivResearch_2.0.0.20*"
FOREACH(Candidate_folder ${PATH_Candidates})
# MESSAGE(STATUS "Found path ${PATH_Candidate}")
LIST(APPEND PATH_Candidates ${Candidate_folder}/doc/examples_Qt/example5)
ENDFOREACH(Candidate_folder ${PATH_Candidates})
MESSAGE(STATUS "Emotiv paths found ${PATH_Candidates}")
FIND_PATH(PATH_EmotivAPI edk.h PATHS ${PATH_Candidates} ${OV_CUSTOM_DEPENDENCIES_PATH})
IF(PATH_EmotivAPI)
MESSAGE(STATUS " Found Emotiv API...")
INCLUDE_DIRECTORIES(${PATH_EmotivAPI})
FIND_LIBRARY(LIB_EmotivAPI edk PATHS "${PATH_EmotivAPI}/../../../lib")
IF(LIB_EmotivAPI)
MESSAGE(STATUS " [ OK ] lib ${LIB_EmotivAPI}")
# To delay load EDK.dll and redistribute binary
#TARGET_LINK_LIBRARIES(${PROJECT_NAME} Delayimp.lib )
#SET_TARGET_PROPERTIES(${PROJECT_NAME} PROPERTIES LINK_FLAGS "/DELAYLOAD:edk.dll")
ELSE(LIB_EmotivAPI)
MESSAGE(STATUS " [FAILED] lib Emotiv edk.lib")
ENDIF(LIB_EmotivAPI)
# Copying of DLL files is not needed anymore because of delay load library
ADD_DEFINITIONS(-DTARGET_HAS_ThirdPartyEmotivAPI)
ELSE(PATH_EmotivAPI)
MESSAGE(STATUS " FAILED to find Emotiv API")
ENDIF(PATH_EmotivAPI)
No problem, if it works in the end, it is essential! To be honest, I was afraid to annoy you with all my log files!
So, the compilation aborted again, see the log file. That look like as programming error (parse error).
Thanks for your help!
- build_log3.txt
- (36.86 KiB) Downloaded 288 times
Looks like you applied the modifications in the wrong directory. You need to apply them in /home/simeon/Logiciels/openvibe-1.0.0/
Hallelujah! It works!!! Many, many, many thanks!!! I could display raw data from my head in the designer! And with gyroscope!
Thanks again for taking your time to help me!
Nice.
I'll put everything clear later for next release.
Guillaume
Guillaume
Re: [Solved] Acquisition server with Emotiv headset on Linux
Hello, I am experiencing the same issues, but with windows. The emotiv driver does not appear on the server acquisition list. Could you please provide me a brief summary of what you did to resolve this?
-Thanks
-Thanks
