Can I get information without designer?
Hello, I´m looking for send by bluetooth raw brainwaves, can i use only acquisition server to send files or a array to a program with a bluetoothSocket?? In that case, can i put some high band and low band filters???
Re: Can I get information without designer?
Without doing some programming, no. If you're ready to code, you could use the LSL Output plugin as an example.
Happy hacking,
Jussi
Happy hacking,
Jussi
