I want to use OpenViBE to read data from a g.Tec g.MobiLab+, however it does not show in the list of devices in the Acquisition server (Windows 7 64-bit, binary version 0.17.1). My lab only has access to the Windows driver, so I can't compile the driver from source as I do not have access to the C API. Does this mean I won't be able to extract real-time data from the g.MobiLab+ at all with OpenViBE, or am I going about this the wrong way?
Hi Cypheus,
Windows gMobiLab+ support is not in 0.17.x and in 0.18 it will only exist as source code. The reason is that we are not aware how to successfully compile both gtec usbamp and gtec mobilab+ support to the same application on Windows. If you can obtain this information from gtec (e.g. a concrete example code with both libs linked that doesn't crash when accessing the devices), we would be more than happy to include both once we know how we can do that. Currently we consider usbamp to be more important of the two so gMobiLab+ will be disabled in the binary OpenViBE.
My previous reply is up-to-date. We are unable to proceed without assistance from gtec. Meanwhile, if people want to use the MobiLab+, they will have to compile OpenViBE 0.18 themselves, enabling MobiLab+ and disabling gUSBAmp.
jtlindgren wrote:My previous reply is up-to-date. We are unable to proceed without assistance from gtec. Meanwhile, if people want to use the MobiLab+, they will have to compile OpenViBE 0.18 themselves, enabling MobiLab+ and disabling gUSBAmp.
Where do i enable/disable this, from the contribAcquisitionServerLinkLibs.cmake ?
jtlindgren wrote:In cmake-modules/, make "FindThirdPartyGUSBampCAPI.cmake" an empty file. That should do it.
hmm, i rebuild it and still doesnt appear in the acquisition-server.
I added also in "..\contrib\common\contribAcquisitionServerLinkLibs.cmake" a line "INCLUDE("FindThirdPartyGMobiLabPlusAPI")"
Ah, do you have the C API from gtec installed? As far as I know, this is not free and cannot be distributed by us. However, it is required to build the mobilab support.
jtlindgren wrote:Ah, do you have the C API from gtec installed? As far as I know, this is not free and cannot be distributed by us. However, it is required to build the mobilab support.
I have it installed under C:\Program Files (x86)\gtec\gMOBIlabCAPI\PC\Lib including both the header file .h and the .lib.
I changed also the path on the FindThirdPartyGMobiLabPlusAPI.cmake to the API location.
It worked for me, so its hard to say what goes wrong.
I'd add MESSAGE("blah...") statements to the Mobilab find script to see what component it cannot find and then check if its there. Note that it expects to find the dll in one of the two locations, "C:/Windows/System32" or "C:/Windows/SysWOW64" depending on the system.
jtlindgren wrote:It worked for me, so its hard to say what goes wrong.
I have the .h and .lib files in the folder. Do i have to built a dynamic library (dll) as well?
