Need help with Emokit OpenVibe driver in Windows 7 x64 OS
beginner
Post by beginner »
I am a Windows user, I don't know C language and have very limited coding ability, I want to install your Emokit OpenVibe driver in Windows OS, I read the instructions on both RayMax's branch and Antoche's branch on github.com, but still have no clue of exactly what to do to install the Emokit OpenVibe driver in Windows.
I have downloaded the latest OpenVibe installation file for Windows from OpenVibe and installed it on Windows 7 x64, I can run the OpenVibe program in Windows, but I need to install this Emokit OpenVibe device driver in order to use the Emotiv EPOC in Emokit mode, can you please help me to understand what exact steps I need to take to install this driver?
Thank you so much!
Re: Need help with Emokit OpenVibe driver in Windows 7 x64 O
Emokit is not supported by OpenViBE. You could try contacting the original authors of this driver/modification and use the version of openvibe which it was designed for. After 0.14, there has been a lot of changes and old external code may no longer work out of box. You can still find the old openvibe versions through the downloads page.
beginner
Post by beginner »
Thank you for your reply.
Since Emotiv is not supported, I will not mention it any more, can you instead instruct me the steps to compile a typical custom build of OpenVibe in windows 7 x64, for the purpose of adding an externally developed device driver? please also let me know what programs/tools I would need to compile the code in Windows 7 x64 OS. With detailed instructions, I will be able to complete the task on my own.
Thank you!
Emotiv Epoc is supported (on Win, Research Edition reqd.), Emokit is not.
For build instructions, see
http://openvibe.inria.fr/build-instructions/
Also, there's a lot of helpful material in the openvibe web documentation.
