Problem about self-disconnection of the Acquisition Server
Obtaining data from various hardware devices
Post Reply
roberto
Post by roberto »
Hi all,
I explain my situation. I'm using the SSVEP online test scenario, and I send the results of the classification to a c++ code, and then the c++ program send that data to Simulink via udp protocol. It happens that when all these things run together (OpenViBE, Visual Studio with c++, Simulink), after a little period of time the Acquisition Server self-disconnect from the device (I am using the Emotiv Epoc), and so the Acquisition Client in the scenario is deactivated and I have to stop the execution of the experiment. Very bad problem.
I don't know, maybe the Acquisition Server doesn't receive some data from the device because the computer is too much charged and for this reason it self-disconnect (the same that happens when you turn of the device), but it's very strange...
Any suggestions? I hope someone can help me.
Thanks,
regards
Roberto
Roberto
Post Reply
