Hi all, I have a little problem.
I've built a shield for Arduino that can acquire bioelectrical signal. It is an anolog front-end based on the modularEEG project and works with the protocol supported by OpenVibe.
I'm working with OpenVibe on Ubuntu 12.10.
Unfortunately I can't link the Arduino platform with the driver on Acquisition Server of OpenVibe.
On my PC the port is know as "ttyACM0" meanwhile with OpenVibe I can choose only "ttySx" and "ttyUSBy" with x from 1 to 9 and y from 0 to 6.
How can I do to work correctly with the device?
What should I modify? On the "OpenVibe side" or on the "linux side"?
Thank you
Arduino with OpenVibe on Ubuntu
Re: Arduino with OpenVibe on Ubuntu
Hi Luighi,
at a glance, the devices displayed in the UI appear to be hard-coded to two files,
ovasCConfigurationOpenEEGModularEEG.cpp
ovasCDriverOpenEEGModularEEG.cpp
Perhaps you could modify these files to try the device names you have available, recompile, and see what happens.
Hi jussy, I've modify that files.
To recompile I only have to launch the "linux-build" script?
Thank you
Thank you
Correct.
Hello, here's a simple solution:
just type
and it works correctly.
Best Regards
just type
ln -s /dev/ttyACM0 /dev/ttyUSB0
Best Regards
