Hi
We are trying to use the TMSI refa8 device in windows 7 64 bit. The device is the one used by Dieter Devlaminck (ddvlamin) and is now in our lab.
We have installed the TMSI 64 bit driver but it the acquisition server says that the device is not connected. Do you have an idea what causes this?
Problem with TMSI Refa8 on 64 bits windows 7.
Re: Problem with TMSI Refa8 on 64 bits windows 7.
Hi pkindermans,
Sorry for the late reply, we were short on manpower lately and couldn't manage the official support.
I updated the hardware compatibility page on the website.
Unfortunately we lost our access to Porti32 and Refa32 amplifiers, thus we cannot test the TMSi driver no more.
I'm afraid we won't be able to help you...
(Dieter are you around? any idea?)
Laurent, the TMSi porti32 amplifier is the same device as the Nexus32 from Mindmedia so you surely can test this one ; the Refa32 however is a different device. You should ask INRIA staff at either Nancy (cortex team) or Sophia (Athena team), they could probably check that everything is in place.
I asked our contacts in Cortex and Athena teams if they can do some proper testings of the Refa driver on a windows 7 64bits configuration.
Let's hope they can do it quickly
Dear pkindermans,
I am also interested in your problem given that I am using the ANT device with TMSI Refa stuff. Where is it possible to download the driver for 64 bits ?
Thanks a lot,
Duvi
Thanks a lot,
Duvi
Sorry guys, but so far no answers ...
I'll keep you posted.
L
L
We still have a problem to connect the TMSi Refa32B on the acquisition server of openVIBE with windows 7 64bits.
The incoming error is:
"there is no device connected to the pc" however the device seems to be recognized by the computer under windows.
The drivers are "PCDrivers_rev7_1_118_0"
When I'm trying Mindmedia neXus32B, I got
"Connection succeeded !" then I start to read and...
"Could not start acquisition with NeXus API, Starting failed !"
However no problem on Windows XP.
If you have a clue to solve this problem...
Louis Korczowski
Student in the Cortex Team (Nancy)
Louis Korczowski
