hi,
i am new to this forum and this software looks really good. i am doing neurofeedback and want to use the 2d and 3d visiualisation, and later maybe more.
however i have the same problems as mgr some posts ago, also the message after 500ms did not receive anything from the driver. the generic oscillator works.
i used two different rs232 to usb converters, both the same problem.
in the log console it also says "warning registery key software vb and vba programm settings/brainquick-system 98/eeg_settings is not initialized"
what does that mean?
thanks for your help
michael
openeeg driver problem
Re: openeeg driver problem solved
i found the solution myself. in driver properties, you can choose com port 1-16. my modeeg was on port25, so i had to change it. i changed it in the device manager, but without reboot of win7. that was the problem. i also set the buffers on low. after reboot i could connect. however i have to change the device drift from 2 to 4, dont know what that does.
michael
michael
Hi michael!
I'm glad you found out by yourself.
A drift happens when the sampling frequency measured differs from the theorical sampling frequency (for example you receive 99 samples instead of 100 per second. after a while the drift can be too high).
L
If you are talking about the drift tolerance in the server configuration, it represents how long (in ms) the server will wait before trying to correct a drift.however i have to change the device drift from 2 to 4, dont know what that does.
L
