no signal acquired.
Locked
Rapten
no signal acquired.
Post by Rapten »
I got the driver listed and tried connecting the device as well.
the connection gets established along with a warning about the drift being too high. The settings are as follows:
The main concern is that no data is displayed, even in a simple scenario like this:
I'm also not sure about the acquisition server hostname, do we need to change it ?
And the screen displays this:
lbonnet
Re: no signal acquired.
Post by lbonnet »
Hello Rapten !
Your scenario is good as the signal display is actually displaying something.
If the connection between acquisition server and client is wrong, the signal display is just blank.
The Acquisition server is detecting a high drift and corrects the signal automatically. This is normal as the Emotiv EPOC is sampled at 128Hz, and default drift correction occurs at 2ms (i.e. 1 sample is enough). Change the drift tolerance to 10 ms, it's a relevant setting value for that device.
You are indeed acquiring signal. The headset is just sending constant, and I assume High level values on all channels.
Other users are experiencing the same (Cent and Nathali on this forum), and we are trying hard to solve this !
I move these posts in this previous one. To centralize everything.
[TOPIC LOCKED]
Locked
