I have a NeuroSky Mindwave Mobile device and have downloaded OpenViBE v0.15.0.
I am unable to connect to the device, even though the NeuroSky apps work (Bluetooth over COM3).
I open the acquisition server, select "NeuroSky MindSet (MindSet Dev. Kit 2.1+)", then click connect, but get this:
[ INF ] Connecting to device [NeuroSky MindSet (MindSet Dev. Kit 2.1+)]...
[ INF ] ThinkGear DLL version: 21
[ INF ] Eye blink detection is possible.
[ INF ] ThinkGear Communication ID is: 24.
[ INF ] Scanning COM ports 1 to 16...
[ INF ] Connection available on port COM1 -- STATUS: FAILED (0 bytes on the stream)
[ INF ] Connection available on port COM2 -- STATUS: FAILED (0 bytes on the stream)
[ INF ] Connection available on port COM3 -- STATUS: FAILED (0 bytes on the stream)
[ INF ] Connection available on port COM4 -- STATUS: FAILED (0 bytes on the stream)
[ ERROR ] The driver was unable to find any valid device on serial port COM1 to COM16.
[ INF ] Disconnecting.
I have even rebuilt from source, but nothing I do makes a difference.
The only think I can think of is that there is a problem because I am running on a 64bit win7 machine.
Can anyone offer any suggestions or help?
Many thanks,
Ed
