Hi everybody,
I've got a little problem with running acquisition server. When I downloaded OpenViBE software and tried to complete tutorial: the most basic OpenViBE setup, the following thing has happened - a lot of missing dlls for 32bit operating system. I checked both Windows 7 and XP to solve this but nothing changed. Any ideas?
Problem with first run of acquisition server.
Re: Problem with first run of acquisition server.
have the .dll's in question been installed, that is, can you find them from your disk? Also, it might help if you copy-pasted the error output here. Can you run other openvibe applications such as designer without this issue?
