It is currently Sat May 25, 2013 10:23 am
Post new topic Reply to topic  [ 6 posts ]
Have you used OpenViBE with Emotiv SDK?
Yes, with the Lite edition. 0%  0%  [ 0 ]
Yes, with the Developer edition 0%  0%  [ 0 ]
Yes, with the Research edition 0%  0%  [ 0 ]
No, but I would like to try it 50%  50%  [ 1 ]
No, there are better devices than Emotiv headset 0%  0%  [ 0 ]
No, technically I failed doing it 50%  50%  [ 1 ]
Total votes : 2
PostPosted: Tue Apr 19, 2011 8:08 pm
Is it possible to start Emotiv Lite and perform a signal simulation that to be recorded by OpenViBE?
In general what can OpenViBE utilize from an Emotiv headset?
-Anton
PostPosted: Tue Apr 19, 2011 8:40 pm
Dear Toncho1,
thank you for your interest and welcome on this board. In order to answer your question, I suggest you start reading the FAQ entry on this issue to be sure you have the appropriate setup. If everything is ok, then follow the procedure described by Laurent in this post
Have fun w/ OpenViBE
_________________
PostPosted: Tue Feb 12, 2013 12:45 am
Hello!!
As i read out in some topics the minimum version of SDK that you must have installed to start making any processing with open vibe and emotiv is "Emotiv Developement Kit_v1.0.0.3-PREMIUM" . Am i correct? Can you work with SDK lite? Or you must own any of the other versions of sdk (>=500$). Thanks in advance!
PostPosted: Tue Feb 12, 2013 7:35 am
Yes, you need the one (>500), because you need a research license which gives you the RAW signal.
The Lite edition won't work.
PostPosted: Tue Feb 12, 2013 12:58 pm
Is there any other eeg that i can use with open vibe withought spending all that money?
For example if i will buy an eeg from any other company will i have to buy the edition with sdk or api?
Thanks.
PostPosted: Tue Feb 12, 2013 2:37 pm
Here is a list of supported hardware.
http://openvibe.inria.fr/supported-hardware/
There's also this list:
viewtopic.php?t=526&p=3251#p3251
Hope this helps.
POWERED_BY
Translated by MaĆ«l Soucaze © 2009 phpBB.fr
