Could someone tell me which protocol the acquisition server is using to send data? Are they encoded in the EBML format?
Yves.
Data format
Re: Data format
Dear yvessi,
the acquisition stream is indeed encapsulated in an EBML structure. Browsing the developer documentation, you will find a description for each stream type. If you are not familiar with EBML, I suggest you first read the following doc pages : If you want some reference implementation, you should look at the openvibe-plugins/stream-codecs folder.
I hope this helps. Can you tell us what particular situation leads you to decode the stream by yourself ?
Re: Data format
Hi Yann,yrenard wrote: I hope this helps. Can you tell us what particular situation leads you to decode the stream by yourself ?
thank you for your quick answer!
I'm interested in understanding the full process of developing a BCI platform for my studies.
And also "comparing" your design to that of: http://openeeg.sourceforge.net/neuroserver_doku/
So is that the "DTD" used for acquisition?
- OVTK_NodeId_Header
- OVTK_NodeId_Acquisition_Header_ExperimentInformation
- ... some experiment information stream header
- OVTK_NodeId_Acquisition_Header_Signal
- ... some signal stream header
- OVTK_NodeId_Acquisition_Header_Stimulation
- ... some stimulation stream header
- OVTK_NodeId_Acquisition_Header_ChannelLocalisation
- ... some channel localisation stream header
- OVTK_NodeId_Buffer
- OVTK_NodeId_Acquisition_Buffer_ExperimentInformation
- ... some experiment information stream buffer
- OVTK_NodeId_Acquisition_Buffer_Signal
- ... some signal stream buffer
- OVTK_NodeId_Acquisition_Buffer_Stimulation
- ... some stimulation stream buffer
- OVTK_NodeId_Acquisition_Buffer_ChannelLocalisation
- ... some channel localisation stream buffer
Yves
Re: Data format
Yes that's it. You will then have to check the {experiment information|signal|stimulations|channel localisation} streams description to decode sub streams.
