Hi brain_ts,
Sorry for the late reply !
Micromed SAM FC1 is not officially supported as stated in the
FAQ.
When roaming on the micromed website, I didn't find much references about it...
The SD LTM driver is in fact a System plus Evolution driver, so it's supposed to work with any device connected to it.
As my former colleague Baptiste said in previous posts, you must have bought the option
SW EEG BCI for the BQUSB interface, so you can send data through network connection.
If it still doesn't work, maybe there is a compatibility issue between the Micromed DLL we're based on and your version of the System plus Evolution.
What does the driver tell you ? It just fails to connect or the error is is more precise ?
_________________
Follow us on twitter >>
openvibebciCheckout my (old) blog for some OpenViBE tips & tricks :
here !
