Hi everyone,
We finally finished to write a patch for OpenViBE to make it work with the Emotic EPOC headset on Linux.
We were using the Educational SDK, but the principle should be the same with the Research (and maybe the Developper one? maybe, we don't know, we hope that some will try and tell us ).
Note the you may have to adapt the code of the installation script before doing anything, this is still experimental and it would be preferable to integrate it in the original OpenViBE source code.
The patch is available at the following address: http://www.github.com/thibaultbronchain/openemo
( Edit, admin, 2015: The current link seems to be https://github.com/tbronchain/openemo )
Don't hesitate to ask us if you have any question/issue.
Best regards,
The IOT Team.
[How-to] Emotiv EPOC integration with official SDK
I Only Think - http://eip.epitech.eu/2013/iot/
A Brain-Computer Interface System
