Hi everybody,
Right now, I am doing some research about BCI for my Final Project and using Openvibe with Neuroheadset Emotiv EPOC.
There's a problem on Openvibe-acquisition-server-dynamic.exe
it had no problem when I pressed the "connect" button, but the program suddenly stoped working.
i had no idea what happen, it's working correctly when i changed the driver to modular EEG.
this's a screenshot when the problem appeared,
Any help?
amufti
Problem with Emotiv EPOC
Re: Problem with Emotiv EPOC
do you have the Emotiv EEG Research edition SDK installed, if yes which version? Is the path to it set correctly in the driver settings?
We will need additional information to be able to help you with this problem.
