A driver for mitsar have been made in the last driver version and I try to convert it to the new one. No problem in logic but I have encountered a graphic interface bug :
When I "connect", then "start" and start fail (not really plugged for instance), I have a error message of "Starting failed!". Here all is OK. After, whatever I click in the window, a new "start" is executed!! I can't use disconnecting button!
Do you have any clue?
EDIT :
probably an idea : dll use visual window to notice error, when disabled, the bug disappear. Could it be a incompatibility between glade and visual window? Why the focus is not restored?
interface bug on mitsar driver
Re: interface bug on mitsar driver
Dear matthieuG,
I can't see a reason for this to happen. Can you confirm you are working in branch wip-goyat of the acquisition server application, and that you uploaded all your sources in the SVN repository ?
I confirm
