However, now, with the latest drivers and the latest OpenViBE source, it seems to work.
I forgot the designer can connect through tcp/ip with the acquisition server. This could indeed spread the load of both applictions over two computers, thanks for the hint.yrenard wrote:the most usual setup here is to have the acquisition server on windows and the designer & other controlled applications on linux...
Kind regards,
Dieter Devlaminck
