Hello, I am constructing the modular EEG and I would like to know how should I acquire the signal once the circuit is finished. I know I should use the acquisition server box, are the drivers for the modular EEG already installed with the version of openvibe I downloaded or should I install them separately?
Also, how are the samples of each channel acquired? The thing is that I had to replace some components that appeared on the schematics in the website, so I need to know how should I send the signal from each channel.
I apologize if I am asking too basic questions, but I am just starting in this field and I am kind of lost in some issues.
Thanks for any help!
Lorena
EEG acquisition using modular EEG
Re: EEG acquisition using modular EEG
I have other consult regarding the acqisition server: I want to try testing the acquisition server using the generic oscilator, but I can't find the acquisition server box among the options. Is it possible that it isn't available in the OpenVibe version I downloaded? (I am using the last release 0.14.2)
Thank you,
Lorena
Thank you,
Lorena
Hi Lorena,
In case it doesn't, I guess you would have to modify the driver code.
The source code of the driver is located in openvibe-applications/acquisition-server/trun/src/openeeg-modulareeg.
You have to use an acquisition client box to connect your scenario to the server.
hope this helps!
A driver for the OpenEEG/Modular EEG already exists in openvibe. It is an early contribution, I hope it will wokr with newer versions of openEEG device.the drivers for the modular EEG already installed with the version of openvibe I downloaded or should I install them separately?
The acquisition server is not a box, it's a dedicated application. Please read this documentation page for further information.I want to try testing the acquisition server using the generic oscilator, but I can't find the acquisition server box among the options.
hope this helps!
Dear Laurent,
Thank you, I found the driver for the modular EEG.
Thank you very much for your help!
Lorena
I have read that document, but still I don´t understand how to use the oscillator to simulate a signal acquisition (That's the intention when using the oscillator, is that correct?). I will continue testing top see if I understand better anyway.The acquisition server is not a box, it's a dedicated application. Please read this documentation page for further information.
Lorena
Hello Lorena,
I have made a tutorial on a very basic OpenViBE setup. Please tell us if you have any more questions after reading it.
http://openvibe.inria.fr/tutorial-the-m ... ibe-setup/
Dear Jozef,
Thank you, your tutorial was really helpful, now I understand better how this works!
Lorena
Lorena
