Problems to connect to my NeuroSky MindWave
Re: Problems to connect to my NeuroSky MindWave
Next 3 screenshots:
- Screenshot-MindWave signals in Open Vibe Designer- DELTA SIGNAL - 20062012.JPG (76.45 KiB) Viewed 6659 times
- Screenshot-MindWave signals in Open Vibe Designer- HIGH ALPHA SIGNAL - 20062012.JPG (78.83 KiB) Viewed 6659 times
- Screenshot-MindWave signals in Open Vibe Designer- HIGH BETA SIGNAL - 20062012.JPG (68.49 KiB) Viewed 6659 times
Next 3 screenshots:
- Screenshot-MindWave signals in Open Vibe Designer AND Signal Information 12 channels, sample count per buffer 8, samplefreq 512-20062012.JPG (59.96 KiB) Viewed 6659 times
- Screenshot-MindWave signals in Open Vibe Designer- ATTENTION SIGNAL - 20062012.JPG (59.56 KiB) Viewed 6659 times
- Screenshot-MindWave signals in Open Vibe Designer- BLINK STRENGTH SIGNAL - 20062012.JPG (73.13 KiB) Viewed 6659 times
Next 3 screenshots:
- Screenshot-MindWave ONLY RAW EEG SIGNAL (Signal name - Electrode) AND Signal Information in Open Vibe Designer -20062012.JPG (94.71 KiB) Viewed 6659 times
- Screenshot-MindWave signals in Open Vibe Designer AND OpenVibe Acquisition Server-20062012.JPG (147.08 KiB) Viewed 6659 times
- Screenshot-MindWave signals in Open Vibe Designer AND Signal Information 12 ch, sampl cnt per buf 8, sfreq 512 AND OV Acq Server STATUS WINDOW-20062012.JPG (84.47 KiB) Viewed 6659 times
These were my 33 screenshots !
Hi All,
The OpenViBe Acquistion Server V0.15 is not able to connect to my Mindwave which works normally on COM4. I read the relevant discussion in Forum and It does not work in my case. I am not sure if it is verison issue. I am downloading the old version V0.14.2 to test again. However, I also post the issue here and want to know any possible reason why it does not work. The error log from console are pasted here. It works for Generic Oscillator, and I can see the output in the display.
I urgently need to complete my brainwave thesis about authentication in 2 weeks. I know a little bit late. By the way, if you have any raw data or discussion about brainwave for authentication, please let me know. Certainly, I searched some related thesis from database. I need to capture the raw data for my report.
Many Thanks
Peter
[ INF ] Kernel module loaded, trying to get kernel descriptor
[ INF ] Got kernel descriptor, trying to create kernel
[ INF ] Adding [../bin/OpenViBE-plugins-*.dll]
[ INF ] Added 2 plugin object descriptor(s) from [../bin/OpenViBE-plugins-acquisition-dynamic.dll]
[ INF ] Added 6 plugin object descriptor(s) from [../bin/OpenViBE-plugins-classification-dynamic.dll]
[ INF ] Added 1 plugin object descriptor(s) from [../bin/OpenViBE-plugins-classification-gpl-dynamic.dll]
[ INF ] Added 1 plugin object descriptor(s) from [../bin/OpenViBE-plugins-feature-extraction-dynamic.dll]
[ INF ] Added 17 plugin object descriptor(s) from [../bin/OpenViBE-plugins-file-io-dynamic.dll]
[ INF ] Added 2 plugin object descriptor(s) from [../bin/OpenViBE-plugins-matlab-dynamic.dll]
[WARNING] No 'plugin object descriptor' found from [../bin/OpenViBE-plugins-python-dynamic.dll] even if it looked like a
plugin module
[ INF ] Added 9 plugin object descriptor(s) from [../bin/OpenViBE-plugins-samples-dynamic.dll]
[ INF ] Added 29 plugin object descriptor(s) from [../bin/OpenViBE-plugins-signal-processing-dynamic.dll]
[ INF ] Added 22 plugin object descriptor(s) from [../bin/OpenViBE-plugins-signal-processing-gpl-dynamic.dll]
[ INF ] Added 17 plugin object descriptor(s) from [../bin/OpenViBE-plugins-simple-visualisation-dynamic.dll]
[ INF ] Added 12 plugin object descriptor(s) from [../bin/OpenViBE-plugins-stimulation-dynamic.dll]
[ INF ] Added 19 plugin object descriptor(s) from [../bin/OpenViBE-plugins-stream-codecs-dynamic.dll]
[ INF ] Added 3 plugin object descriptor(s) from [../bin/OpenViBE-plugins-streaming-dynamic.dll]
[ INF ] Added 4 plugin object descriptor(s) from [../bin/OpenViBE-plugins-tools-dynamic.dll]
[ INF ] Added 4 plugin object descriptor(s) from [../bin/OpenViBE-plugins-vrpn-dynamic.dll]
[WARNING] Registery key Software\VB and VBA Program Settings\Brain Quick - System 98\EEG_Settings is not initialized
[ INF ] Connecting to device [Generic Oscillator]...
[ INF ] Connection succeeded !
[ INF ] Disconnecting.
[ INF ] Connecting to device [NeuroSky MindSet (MindSet Dev. Kit 2.1+)]...
[ INF ] ThinkGear DLL version: 21
[ INF ] Eye blink detection is possible.
[ INF ] ThinkGear Communication ID is: 0.
[ INF ] Scanning COM ports 1 to 16...
[ INF ] Connection available on port COM4 -- STATUS: FAILED (0 bytes on the stream)
[ INF ] Connection available on port COM5 -- STATUS: FAILED (0 bytes on the stream)
[ ERROR ] The driver was unable to find any valid device on serial port COM1 to COM16.
[ INF ] ThinkGear Communication ID is: 1.
[ INF ] ThinkGear Communication ID is: 2.
Many Thanks
Peter
plugin module
Hi All,
I have installed the old version 0.14.2 but it does not work for my Mindwave either.
The Win Device Manager shows Mindwave USB adapter. I am using Win7 Pro 32 bit in Parallel 8 in Apple MAC Pro.
Thanks in advance for your help.
Peter
Peter
Hi Peter,
only the SVN version of OpenViBE works with MindWave Mobile. Supporting it is a very new development. There is no release version yet that'd work with it.
