Unable to use Acquisition Server with Brain Products amplifiers (through BrainVision Recorder)
Posted: Mon Apr 17, 2023 5:07 pm
Hello,
We are using the 3.5 version of OpenVibe and the 1.24.0001 version of the BrainVision Recorder.
We are trying to set up the connection between the Acquisition Server and the Brain Products amplifiers (through BrainVision Recorder).
We launched the BrainVision Recorder, enabled the Remote Data Acquisition (RDA) option.
We launched the Acquisition Server, selected the Brain Products amplifiers (through BrainVision Recorder) option, set up the defaults parameters et driver properties (local host ; port 51244).
We hit Connect, which resulted in a "Connection Succeedeed" message,
When we hit Play, we got "Starting the acquisition..." , "Now acquiring..." but the GUI closes (.exe file fails ?) without any other message, log, error... in the cmd window
Do you have an idea of what the problem could be?
We have "Kernel_MainLogLevel = Trace" in openvibe.conf
Is there a way to access more logs about the Acquisition Server ?
Thanks a lot,
Thanks a lot,
