Sorry because I came back again about the connection between Openvibe and Unicorn Hybrid black!
I need an information!
I am an Openvibe user; I am going to buy a Unicorn Hybrid black. I will buy it only if it is possible
to connect the Unicorn Hybrid black to Openvibe via a driver. In the Acquisition server (Openvibe 3.2) I see that there is a driver for this connection.
But if I try to click on “Driver properties” , I have no result and I dont’see any new information.
Is this driver working? I need to know this information because I would avoid to use LSL.
Thank you
Etc
http://openvibe.inria.fr/documentation/ ... ml#details
I need an information before to buy a Unicorn Hybrid!
Re: I need an information before to buy a Unicorn Hybrid!
Hi Etc,
I haven't had the chance to test the Unicorn but I know why the Driver properties will not appear.
The driver is very minimal and no configuration has been developed. The acquisition should be working fine and use the default configuration of the device.
You could try contacting Anton Andreev, from Gipsa-lab for more information.
Cheers,
Thomas
Cheers,
Thomas
Thank you, Thomas!
Very Gentle!
Etc
ps do you know how can I contact Anton Andreev? Have you his email address at Gipsa-lab?
Very Gentle!
Etc
Hi Etc,
The driver and the device are not well tested by us. For some reason we keep using "wired" gtec amplifiers instead of the Unicorn Black.
Maybe someone else did test it.
The comments of Thomas for the driver are correct.
Unfortunately as of today we can not provide more info on the quality of the EEG signal the AS driver.
Only today I read your answer!
Thank you very much!
